G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I just built a new PC with P4C800-ED, and I replaced the case fans with
better ones, but I
got all 4 pin types, but now I want to monitor the RPM of one of the front
case fans. It is difficult to get to the fan, so I would prefer to get an
adapter to connect the fan to the mainboard, to monitor the RPM.
I have searched, and all I can find is a 4 pin to 3 pin w/o RPM wire.
Does anyone know of a 4 pin to 3 pin with RPM wire? (or a 4 pin to 4 pin
with addtl RPM wire, if it exists.)
Finding 3 pin to 4 pin adapters with RPM is easy, but of no use to me.
Thanks,
QZ
better ones, but I
Thanks,
QZ
