Connect Car Audio system to home audio system speakers ?
chngupt
Hello,
I own a Sony Home Audio system which has 2 portable Speakers. Due to some reason, the system is not working. It is not repairable also.
Instead of buying a new home audio system, i wanted to the following;
1. Purchase a Car Audio System - without the speakers/woofers
2. I already have the Speakers from the home audio system.
Can i connect these two together?
How to go about it?
Kindly guide me for doing this.
Thanks in Advance.
Regards
Sac
What do you mean? You mean get a car receiver and amp and hook it up to your existing speakers..? It would be easier to just get a Home Theater Receiver since they can put out upwards of 80W a channel, compared to a car receiver which puts out like 15W, plus, I wouldn't even know how to hook that up.
Since a car audio system is meant to operate on 12volts dc you would need to buy a large 12v dc power supply to get it working (or use a car battery and charge it when it goes flat). Probably better and cheaper to buy a cheap stereo receiver or something used. Car stereo power ratings are pretty inaccurate so don't assume that the power will be adequate.
