Question Connect fan Cpu and SATA cable
Haji13680201
Commendable
Apr 20, 2019
75
Please don't spam the forum, keep it to 1 thread
I bought a system with the following specifications
Power 1200 w
Cpu 4790k
RAm. 4* 8g. 32g
Asus z97 Deluxe motherboard
ssd 240gb crucial bx500 for only install win
hhd 8tb western digital for data and install all software s and game s
hhd 500g. western digital For data
VGA 1650s Asus
Fan cpu ...noucta dh 15 this fan have a Y-cable and two fan
Please see photo of Motherboard manual...
Q 1. This fan Cpu ... Connect which ..cpu fan ..or.... Cpu opt.... or Cha fan .?? Use y cable ? According to this Nocta dh 15 and this motherboard. What is the best way to install a fan?
Q 2.
I have 2 hhd and 1 ssd .. ssd 240gb crucial bx500 for only install win
Now
This hard drive s . Which port to connect to ??
Intel SATA or asmedia SATA ....??when better for me?
Q 3. Is Rapid Storage in bios settings enabled or disabled ?? Or...
https://filebin.net/yr35c4simzgfolwq/Screenshot_20220101-195631.png
https://filebin.net/yr35c4simzgfolwq/Screenshot_20220101-195141.png
please help me
Connect d15 fans using y cable to cpu_fan. Opt is optional for pumps or another fan if don't use y cable. Y cable for convenience. Don't use cha fan, these are for case fans. Cpu_fan header needs to be connected so motherboard knows cpu is being cooled.
Which sata port? Intel, primary chipset for best performance.
Rapid storage, don't really need it unless setting raid array.
https://www.dell.com/support/kbdoc/en-au/000132387/what-is-intel-rapid-storage-technology-software
Thank you for help me... install Nocta dh 15 whit y cable .. in fan Cpu... Working very good..
And install 3 hard drive in Intel SATA ... In settings bios show all hard drive ...
But when install win .. no show any hard drive ...and I can install win..
Please help me
Have one drive connected when installing Windows. This prevents boot partitions put elsewhere. If that happens and you remove one of the drives containing boot partition for whatever reason or it died, Windows won't boot. Connect the two after install.
Assuming Win10, follow these steps.
