Hi, I'm using MSI B450 Tomahawk Max and there is no ARGB header for this motherboard. I got 2 ARGB hub with 1 Deepcool convertor.
1 hub is CoolerMaster Hub, 1 is darkflash DR12 Pro hub
If I connect 1 mobo sync pin to the convertor, it's work but the problem now is 1 got another hub.
I wonder if I can connect 2 hub's mobo sync to a ARGB splitter and connect it to the Deepcool convertor then connect to mobo. So that i can sync all hub togther with 1 Deepcool convertor?
2 hub mobo sync --> ARGB Splitter --> Convertor --> mobo 12V RGB slot
