connecting an ethernet only AV receiver to wifi network?
keithym53
I have a home theater AV receiver that has the ability to access Internet radio when connected to Ethernet. Unfortunately, the receiver has only an Ethernet connector on it, and does not support WiFi connectivity. I am not able to pull cat5 to the receivers location, but do have WiFi coverage in the room where it is. Is there some way to configure a WAP to accomplish this?
Thank you.
Access points usually do not have this functionality, but a wireless bridge will do the trick. I use this one, but searching for "wireless ethernet bridge" should get you many other results.
