my recent thread ended up with no solution...
https://forums.tomshardware.com/threads/mw305r-router-keeps-turning-off-in-wds-bridge-mode.3585959/
i've to connect two routers which are across the street... i failed to connect them using WDS Bridge and had to put ethernet...but could not manage to get rj45 jacks.
so I found:
2 small cat6 patch cables
2 rj45 wall sockets (1375055-9)
a long cat5 cable(2 pairs)
View: https://imgur.com/q9ivPUX
what i want to do is connect the cat5's both ends to the wall sockets but im unsure about which wire goes to which pin.
the cat5's wires are:
white green
green
white orange
orange
so the connection would be :
router 1 -> cat6 -> wall socket -> cat 5 -> wall socket -> cat 6 -> router 2
so I found:
white green
green
white orange
orange
