It to a point depends on where the extender is located. If it is near your computer your best option would be to use the wifi card to connect directly to the main router. You would not have the overhead of the repeater in the path.
If the direct wifi does not work well it should help to use ethernet connected to the repeater. You have eliminated 1 extra wifi signal that can get corrupted. You have in effect made a wifi adapter you connect via ethernet than say USB. If nothing is actually going to use the repeater function it will help your performance to disable the repeater function and use the device as a simple client-bridge. When it runs as a repeater it will transmit out data that interferes with the signal from the...
