Question connecting pc to switch doesent work
Sep 2, 2019
if i take a lan cable that goes from my router and plug it into my pc it works fine but if i take the same cable and put it into a networking switch and take a second cable from the switch and plug it into my pc it doesent work
here's the twist it´s not because the switch doesent work because all other devices that are pluged in works on it (tv ps4 xbox one)
note ive already tried setting a static ip and setting a dns for ipv4
yes theres a signal going through
ive checked the cable with a ps4 that works
the swtich is fine since it works with tv ps4 and xbox
->ps4 works
router -> switch ->tv works
-> xbox works
-> pc not working
