connecting problems with subwoofer
Proffa3
29
SO im going to buy Pioneer SP-BS22-LR
bookshelf speakers and Acoustic Audio - Acoustic Audio Cinema CS-PS8-B 300W 8" Powered Black Subwoofer Home Theater Sub - Black to my room setup. I nowhave labtc 285 pulse what isnt that good. i was thinking if i could connect speakers to subwoofer and then the subwoofer to my computer. do i need diffferent or now amp for that. i hope i dont need because i dont have so much money now. pls answer quikly 😉
im from finland and my budget is under 300 euros. But i will use thease to gaming and music listening in my room what is like 5m x 5m + 3,5m x 3,5m. and the amp that i mentioned. is it good inaf?
The sub is an excellent budget model mate.
The pioneer bookshelf speakers are good too - to me you would get away with a cheaper pair if running low frequencies through sub.
The amp mate, no - the mini pyle amps are fairly crap IMO.
The quality of audio will require solely on the amp at the end of the day.
Where would you be buying from ??
