Hey there, I'm currently working on a Corsair Carbide Series SPEC-DELTA RGB Case, which comes with 3 RGB LED fans.
They connect to the board via 3-pin fan connectors, which is fine, but the lights connect via standard onboard RGB header.
All of them are connected to a single RGB 4-pin plug via included Y-cable. The problem here is, the board I am working with has no RGB header.
Now my question is, how am I going to get those to work?
Since it's a simple RGB connector meant to be plugged into the boards RGB header, wouldn't any cheap RGB controller work?
Here's what's available in my area.
It would be nice to either be able control it with a remote (which doesn't have to be connected via a cable, if possible) or via software, since I do have a free internal USB 2.0 header.
I hope you guys can guide me a bit and help me find a product which isn't overly expensive, maybe even from my provided list.
Cheers!
Cheers!
