Connecting wireless headphones to TV
Beasty_993
Commendable
Apr 9, 2017
40
I have a Samsung ue55ku6072u TV and i would like to connect my wireless headphones(sony tmr rf865r) to it but i have no idea how. I tried to just plug them in every port that i could but it didn't work. Is an adapter or something else like that needed?
wow, I did not think that Samsung is really stingy and did not include a headphone jack or RCA audio output.
So...
On the TV side, you have only optical audio output.
On the headphone side, you have only the usual headphone jack and RCA (white and red).
This means, you need to buy a converter from optical to any of those e.g.
https://www.amazon.de/Analog-Stereo-Audio-R-L-Konverter-Adapter-optischem-Heimkino-Systeme-AV-Verst%C3%A4rker-schwarz/dp/B00KNNSKV0/ref=sr_1_1?ie=UTF8&qid=1532588402&sr=8-1&keywords=optical+audio+to+rca
most television either come with Bluetooth or not, this is usually the way headphones are use, using a wifi connector into a usb plug into a tv usually doesn't work as it is nt designed (Tv) to install drivers for your plug in therefore isn't capable of utilizing it.
1. your manual is located http://downloadcenter.samsung.com/content/UM/201612/20161209100212986/ENG-JZDVBEUK-1.1.3.pdf
2. 3 pages from the top index page you have sound section and as I mentioned above it uses Bluetooth, sound bar or headphones should work.
I am sorry but i do not understand what to do. I have a headphone stand that i should be able to connect to it but i cannot.
sony tmr rf865r?
This one comes as pair, the base and the headphone.
TV to base ==> cable
Base to headphone ==> wireless
The base unit should be plug into the normal headphone jack on the TV.
Theere is some settings in TVs so that you can enable the headphone jack.
Find it! Activate it or you can not hear a thing.
I do not think i have the required ports on my tv to be able to connect it to the base of the headphones.
https://imgur.com/MsMiZf8
https://imgur.com/Jja33Qw
So...
