HI,
i would like to ask you some question,
1 Can i link two different pc's on a different internet position with the vpn creation from windows ?
for example: a laptop is what would log in instead the desktop is going to be the worktower, I have already tried and it works.I got some problems that i searched on internet the Windows VPN and it seems that it work randomly sometimes yes sometimes no.
2 If not, can i use a vpn connection for example like WinScribe, to connect the pcs? or it's just a private connection that secure your navigation?
For Example i'm connecting to a VPN with the laptop and the desktop shouldn't be the same like i already did?
We are talking about a close local VPN so it should be work like at house or university, no?
I'm a little confused about this Connections, because i even proved at university and it works for a while, than it stops and dosean't work again.
It's seem to me that Windows VPN can't connect always.
Exactly what i need is to create a share folder on a PC tha can be access by other 2-3 pcs from internet, so that they can edit it too, from other location, is possible?
