Hello everyone,
Recently I found a problem when I wanted to see other PCs on my local network. I could see only myself and the wifi router even though there is one more PC connected to the router via ethernet and many more devices connected wirelessly.
Here comes the real issue. I assumed that to make those PCs visible, I would need to adjust the router settings somehow. I googled around a bit and found out how to find the address of the router settings' page. First thing I noticed was that for me the page(and the Default IPv4 Gateway) was 172.30.20.10, not the usual 192.168.x.1. I even tried to ping the default gateway and received a response. When I connected to the address, though, it immediately refused my attempt to connect(ERR_CONNECTION_REFUSED).
My network is set up through a satellite, where I have a modem connected right before my wifi router, which is made by TP-LINK. I do not have any manual whatsoever to the router, as my father bought the router directly from our local ISP.
I really don't know what to do at this point, so I am looking forward to your replies.
Here is my ipconfig excerpt, I hope that it helps you in some way:
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::10f5:255b:f8e1:685d%5
IPv4 Address. . . . . . . . . . . : 172.30.20.16
Subnet Mask . . . . . . . . . . . : 255.255.255.224
Default Gateway . . . . . . . . . : 172.30.20.10
Tunnel adapter Local Area Connection* 2:
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:953c:2058:154e:6100:e5d6
Link-local IPv6 Address . . . . . : fe80::2058:154e:6100:e5d6%2
Default Gateway . . . . . . . . . : ::
