Hello, so I am a standard domestic internet user with little to no network knowledge...
Recently I moved back to my mothers house and I noticed that my connection had some lag spikes. I reset the router, updated firmware, etc... Still lag spikes every 3-4 seconds. So I switched my router to the one that my internet provider gave me, and i had the same issue (I'm talking about the connection to 192.168.1.1 here).
So basicly after performing several tests, these are my results:
-Connection between PC and ASUS Router = lag spikes
-Connection between PC and standard Router = lag spikes (less intense)
-Connection between Smartphone and ASUS Router = lag spikes (more intense)
-Connection between Smartphone and standard Router = lag spikes
now, here comes the interesting part... It would seem that there is a connectivity problem in my house, as it is highly unlikely that both my 2 routers have been damaged during the 6 months I have been out of this house. So I performed an additional test, using my Smartphone as Hotspot... I also placed it exactly where the other 2 routers were... No lag spikes. Whatsmore, connection has the lowest ping (less than 1ms).
I must add that, performing the Ping test in both my PC and Smartphone at the same time, lag spikes didn't happen at the same time, though they showed a predictable pattern within each terminal.
So, my final guess here is that my routers are old and I should change them. However the ASUS router is expensive as shit, and I find it hard to believe that it is malfunctioning...
Any thoughts on this issue? Should I change my router?
