I currently have the 760 from 2013 and it's been a great card, and to be honest it ran the Battlefield1 alpha and beta just fine at 60hz 1080p ( i dont recall the reso 1920x1080 i think) with HIGH settings I think. However, I'm curious if anyone knows how much of an improvement upgrading would actually provide. The card I want to buy is the 1060 SC 6G, it's running around $250 ish. I have a 1ms monitor that can max at 76hz I believe, but I stay in 60hz. Thanks for your input in advance!
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130937
4GB 256-Bit GDDR5
Core Clock 980MHz
Boost Clock 1033MHz
2 x DVI 1 x HDMI 1 x DisplayPort
1152 CUDA Cores
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487261&Tpk=N82E16814487261
6GB 192-Bit GDDR5
Core Clock 1607 MHz
Boost Clock 1835 MHz
1 x Dual-Link DVI-D 1 x HDMI 2.0b 3 x DisplayPort 1.4
1280 CUDA Cores
4GB 256-Bit GDDR5
Core Clock 980MHz
Boost Clock 1033MHz
1152 CUDA Cores
6GB 192-Bit GDDR5
Core Clock 1607 MHz
1280 CUDA Cores
