Eternally getting a no signal from running 970 evga adapter. Less frequently getting occasional problems supplying 970 with power (I assume as fans don't kick on.
1. Suspect it may be mystery problem due to recent case structural damage.
2. Suspect loose or very sensitive connections on card for power.
3. Suspect issue with how modular power supply is being cabled to mobo, maybe cables themselves.
4. Suspect BIOS issue on Mobo and possible BIOS issue on Graphics card.
5. Wondering if checking power points manually might help.
Conclusion try a "bench test", ensure good BIOS flash to mobo and vid adapter.
asrock z77 oc edition, 8gb 1866 gskill mem, evga 970 acx 2+, ssd + 3/4 hds, d5 laing pump, seasonic 850 gold modular psu, 3770k intel i5, dvd drive, 6 120/140 fans, usually 3/4 usb devices.
