Hi,
sorry in advance for my english, i hope to explain my issue clearly.
I use Armoury crate to control the led effect on my ROG build PC. the latest version of the software seems more stable than the previous ones and the aura sync is working just fine across all the hardwares that support it.
But i still have an issue i have never been able to solve since i built this PC:
Basically, when i turn on my PC, all the parts (MOBO, VGA, RAM, etc...) still use a default led effect (similar to the aura colour cyrcle, but not the same) which i can't seem be able to change/control.
1)I turn on the PC
2)the leds on the rog hardwares use a default cycle effect that appears no matter what my aura sync settings are.
3) i log into my windows account, asus armoury crate starts up.
4)the leds automatically switch to the actual effect i have selected in armoury.
How can i fix this problem? how can i make sure the aura effect i select, starts from the beginning?
I am not totally sure that it is an armoury problem, because the led issue appears when the software is not running yet...maybe something needs to be changed in the bios?
i hope someone can help, let me know if anything on my message isn't clear.
1)I turn on the PC
