converting leads help!
kjtech
20
hi everyone i have 3 screen witch have a hdmi port and a duel link dvi-d port
the graphic card gtx 660 has One Dual Link DVI-I, One Dual Link DVI-D, One HDMI, One DisplayPort
can i convert the dvi-I to a dvi-D on the card ?
so i can run 3 screens ?
Both the dvi-I and dvi-D ports should work. with the dvi-d port on the monitor.
The dvi-I also sends analog signals in case you have a crt type display.
Both dvi-I and dvi-d send the digital signals your monitor can handle.
HDMI sends digital plus sound if your monitor has speakers that you want to use.
great so i can use dvi-D on my graphic card witch has a dvi-I
