Converting NTFS to Fat 32 using Partition Magic 7
cutter
201
Archived from groups: microsoft.public.windowsxp.customize (More info?)
I'm considering converting NTFS to FAT 32 using Partition Magic 7.
Anyone any experience of doing this. I understand Winxp pro has its
own application for doing this but I am used to working with Partition
Magic (in another life). Advice or experience would be appreciated.
Thanks.
I use PM 8.0 with no problem...
"Cutter" <garbage-address@virgin.net> wrote in message
news:ce7fs0190mhd6gee8adl4cp30ttq7ssa80@4ax.com...
> Thanks.
> Thanks.
PM8 is the only version fully compatible with XP. I strongly recommend
upgrading before trying anything.
Facon - the artificial bacon bits you get in Pizza Hut for sprinkling
on salads.
XP does not have anything for doing it in that direction
PM 8 will do so, but you must make sure first that there are no
encrypted files; no compressed files or folders (such as the hidden
$NTUninstall. . . ones) and no files too large for FAT 32 (4gb minus a
few bytes)
Make sure of your backup first in case the thing fouls up mid way
Alex Nichol MS MVP (Windows Technologies)
Bournemouth, U.K. Alexn@mvps.D8E8L.org (remove the D8 bit)
Do not use PM7 for it
WBR, Tom Frisch
HideIt! - The best wizard to hide folders and files
http://www.guard-software.com/
