Question Cooler fans runner exteemely loud but cpu is idling at 50 degrees
gabness1
Commendable
Mar 1, 2019
111
I just installed my new cooler master AIO and i checked temps with HWmonitor and the CPU is idling at 50 degrees, the fans are louder than expected too and with my stock AMD cooler I would usually get around 30 degrees! Does anyone know any fixes for what might be causing this?
Oh ok, whats a good app for monitoring temps? Also, is it normal for a first time usage of an aio to be hot or something because after that it cooled down a bit to about 35?
I tested it with prime 95 it got to 95 degrees in 10 minutes, stopped the pc, and I remembered I forgot to take off the plastic that goes over the copper part of the aio. I am so dumb
