Okay I was finding that my ryzen 5 2400 stock was getting a bit hot for my liking uptown 70c full load on the stock and stealth cooler
I bought the cooler below to replace it and have found that is not really any better sitting hitting late 60s. Also can't even control the panel though Asus panel anymore.
ARCTIC Freezer 13-200 Watt Multicompatible Low Noise CPU Cooler for AMD and Intel Sockets with pre-applied MX-4 High Performance Thermal Compound https://www.amazon.co.uk/dp/B0048F64DU/ref=cm_sw_r_cp_apa_EcaSBb0QRPEGD
bought from Amazon considering I've put this cooler on. Do you think I can return it and get my money back
