T takis1974 Mar 11, 2018 7 0 10 Mar 11, 2018 #1 Would the Cooler Master Hyper EVO 212 fit in a Thermal take Suppressor F51 chassis ?
Solution A A aquielisunari Mar 11, 2018 takis1974 : Would the Cooler Master Hyper EVO 212 fit in a Thermal take Suppressor F51 chassis ? Will it fit? Let's see. I need to check on the dimensions of the 212. http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/ says Heat Sink Dimensions 116 x 51 x 159 mm (4.6 x 2.0 x 6.3 in) THe important number there is 159mm which is the cooler's height. Then we look to the case. http://www.thermaltake.com/Chassis/Mid_Tower_/Suppressor/C_00002676/F51_No_Window/Specification.htm and http://www.thermaltake.com/products-model.aspx?id=C_00003077 (without or with a window) both say Clearance CPU cooler height limitation: 185mm That means it will easily fit into either case.
The Paladin Polypheme Ambassador Oct 5, 2016 9,663 60 67,340 www.texastandyrestorations.org Mar 11, 2018 #2 I don't see why it would not, the Thermaltake Suppressor F51 is a standard Mid tower case. Upvote 0 Downvote
4745454b Titan Moderator Apr 29, 2006 29,241 437 93,590 Mar 11, 2018 #4 MERGED QUESTION Question from takis1974 : "Hyper 212 Evo in a mid-size atx tower" takis1974 : Can you tell me if the Hyper Evo will fit in a Thermal take Suppressor F51 tower ? thank you . Upvote 0 Downvote
4745454b Titan Moderator Apr 29, 2006 29,241 437 93,590 Mar 11, 2018 #5 MERGED QUESTION Question from takis1974 : "Hyper 212 Evo in a mid-size atx tower" takis1974 : Can you tell me if the Hyper Evo will fit in a Thermal take Suppressor F51 tower ? thank you . superninja12 : easily , no problem at all. Upvote 0 Downvote
A aquielisunari Judicious Mar 31, 2011 6,499 14 33,015 Mar 11, 2018 Solution #6 takis1974 : Would the Cooler Master Hyper EVO 212 fit in a Thermal take Suppressor F51 chassis ? Will it fit? Let's see. I need to check on the dimensions of the 212. http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/ says Heat Sink Dimensions 116 x 51 x 159 mm (4.6 x 2.0 x 6.3 in) THe important number there is 159mm which is the cooler's height. Then we look to the case. http://www.thermaltake.com/Chassis/Mid_Tower_/Suppressor/C_00002676/F51_No_Window/Specification.htm and http://www.thermaltake.com/products-model.aspx?id=C_00003077 (without or with a window) both say Clearance CPU cooler height limitation: 185mm That means it will easily fit into either case. Upvote 0 Downvote Solution
A aquielisunari Judicious Mar 31, 2011 6,499 14 33,015 Mar 11, 2018 #8 takis1974 : Thank you !! You're welcome Upvote 0 Downvote
