This is my first build, and I am having trouble figuring out how to connect the 932 HAF's four case fans to my Asus P6X58D Premium motherboard and/or power supply. The fans have 3-pin connectors as well as 4-pin molex adapters.
Three of the fans are 230mm x 30mm, with one also including the LED. The fourth fan is 140 mm x 25 mm.
Since the Asus board has only three chassis fan connectors, one fan has to go directly to the power supply.
1) Which fan should I connect directly to the power supply, bypassing the motherboard? The 230x30 with the LED, since it consumes the most power? Of course I'd give up fan control via the Asus utilities.
2) On the motherboard, two of the fan connections have three pins, while the other fan connection has four pins. The three-pin connections are for:
GND
+12V
Rotation
The four pin connection is for:
+5V
CHA FAN IN
CHA FAN PWR
GND
So, if I plug the front 230x30mm with LED into the power supply, that leaves me with two 230x30 fans and a 140x25 fan to connect to the motherboard, and I don't understand the difference between the three-pin and four-pin connections in terms of where to put the remaining fans.
Can anybody please help me out? I'm actually finding this to be the most vexing problem of the entire build... everything else is basically done.
Thanks,
Brian
GND
+12V
Rotation
+5V
CHA FAN IN
CHA FAN PWR
GND
Thanks,
Brian
