Cooler Master CM690 III Cooling solution
Hey guys
So I have this case with the original coolers: 200mm front intake and 120mm back outtake.
Considering on buying 2x140mm to improve the cooling inside the case although I have no major problems.
You can see my gear on my profile.
So what should I do? Leave the 200mm in front and install the 2x 140mm on top for outtake?
Or the 2x 140mm in front for intake and the 200mm on top for outtake?
I still have the 120mm rear outtake and my Zalman CNPS 9900Max pushing towards the rear.
Any thoughts or advices?
The Zalman CNPS 9900Max is supposed to be a good CPU Cooler. In the same degree of performance as the Noctua NH14, although a little louder.
Maybe I need to take it off, put some new Thermal paste and put it on again..
I also think that 60C may be a little to high for a 6700K at stock..
Well I decided to order 2 of these babies: Corsair ML140 PRO Red.
http://www.corsair.com/en/ml140-pro-led-red-140mm-premium-magnetic-levitation-fan
I'm going to put the 200mm cooler from the front to the top back for outtake, with the 120mm in the back also for outtake and mount these 2 in the front for intake.
Hope to get some extra cooling with the good looks. These will at least look cool with the red leds in the front of my case.. :)
