Cooler Master Elite 130 Heatsink Help
oblivion666
91
So, I am planning on building a Mini-ITX computer using the Asus Impact! The case I will be using is the Cooler Master Elite 130 because I wanted an optical drive. The processor I will be using is a Intel 4670k and I would love to give it a slight overclock (nothing above 4.0). So, I have a main question here for anyone who owns this case or might possibly know the answer. Since the power supply hangs right over the CPU socket on this case, what is the most effective air heatsink I can use with this case that will fit? I know this case can only fit a select few heatsinks due to the way it was designed. I do not want to use liquid or water cooling at all. The case dimensions are 9.4" x 8.1" x 14.9" and I am using low profile RAM. I will link below every product I'm using in this setup via newegg.
To sum it up I am looking for a strong air (not liquid) heatsink that will properly cool a 4670k while playing games that will fit inside the Cooler Master Elite 130.
Any recommendations for heatsinks that would fit this case will be much appreciated.
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119286
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132039
Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139050
Graphics
Asus 580 GTX
I have built a similar configuration with this
CPU Cooler:1 x Prolimatech PRO-SAM17 Samuel 17 CPU Cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835242009
CPU Fan:1 x GELID Solutions FN-PX12-15 120mm Case cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835426015
This configuration fits perfectly the Maximus VI Impact and LP memory
I put the PSU on a pull configuration
1730724
