Cooler Master HAF 912 Plus advice
computerwonder
147
Is this case any good ive checked the reviews and people say its the best budget case however im wondering if it will accommodate my equipment. The main worry is the Antec Khuler H20 620 mounting it onto a Asus p8z68-v-lx with the hole be big enough in the HAF to do this?
Also whats the cable management like?
Thanks
I have one and my 212 evo fit in it with lots of room to spare. Cable management looks like it would be ok if I would have gotten a modular psu. There are 5 holes I believe for cable routing. 1 on the bottom, 2 on the top, and 2 on the right side.
If you do not get a modular PSU it can be hard. Also make sure you put the cables through the top and bottom holes BEFORE you install the PSU. I had trouble getting my connectors through the holes because the mobo and psu blocked the space so it was too small :/.
