adimeister writes:
> Oooooh I didn't know there was a roof. Sorry. So yea, putting it there
> at the top is also fine. Still isolated from the entire rig's heat.
Hehe, yup! This evening I swapped out the PSU in my 932 for a 1475W,
so I took some pics afterwards. Here's the top of the case:
http://www.sgidepot.co.uk/misc/vpc08.jpg
There's a fair gap between the PSU and the top case grill, so I've stuffed
the unused 12V mbd cable into the gap to keep it out the way. The extra
Gelid intake fan can be seen on the right.
Change the number in the above URL from 01 to 10 for some other pics.
Since I've fitted different PCIe cables for this PSU, I took out all the GPUs
and am temporarily just running with a single EVGA GTX 460 FTW. I'll stick
all the 580s back in later once I'm sure the oc is running ok.
> But for a tall case like that, it's much better to put it on the bottom,
> lower center of gravity, and avoid tipping it (you'll be surprised at
> how easy to tip a case when you have the high capacity PSUs haha).
Nah, not really. But then, I have mine with the wheels fitted, so it moves
around easily without any tendency to tip. Darn thing's so heavy anyway,
the PSU at the top doesn't seem to make much of a difference, though I
bet it would be more of a problem if I'd fitted the base with studs instead
of wheels. I like the wheels though; in addition to easier movement, I like
the way they have a little brake lever on a couple of them so one can fix
the unit in place.
Btw, I thought JobCreator made a very good point about heat normally
rising, so I decided to reverse the directions of the side and base fans;
the latter are now intake, and the side fans exhaust:
http://www.sgidepot.co.uk/misc/vpc04.jpg
Notice the inline coupler for the side panel fans, so that I can disconnect
the panel & put it to one side, without having to faff around with the
connector on the mbd. Also, the kink in the cable is so that it hooks
around the side of one of the fans when the panel is fitted, preventing
the cable from getting caught in the fan blades.
Ian.
