Cooler Master HAF Stacker 935 watercooling options
papjim
13
I know it's probably gonna sound weird, the thing I'm about to ask but it's the best solutions I can think of. I have the case mentioned above and I want to watercool my CPU. I want maximum airflow, so going with recommended configuration (small case on top of the big one), doesn't really suit me.
So I've got to ask, is there a pre-filled watercooling kit the has long enough tubes to reach from the cpu to the bottom where the small case will be (it may be close to 46-47cm long tube)?
I need OC and the lowest possible temperature. But I asked just to see if it is possible. If it's not I'll go for a 140mm cooler.
