Cooler master Hyper 103 vs AMD 880k stock cooler
Zdenekk
52
I'm planning upgrading from AMD 740 to AMD 880k. 880k is packed with the new stock cooler (Not wraith).Which cooler is better my CM Hyper 103 or the 880k's stock? And i also wonder if i can fit it in my mATX case (Zalman T4) with mATX mobo (Asrock FM2A58M-DG3+)
I honestly don't think there will be a lotbof difference but yes I'd give the amd cooler a try out .
That's a budget board & you've only been running a 65w CPU on it till now
Be aware you need to update the bios while you have that 740 in to run the 880k.
So when i get the 880k i should change the cooler to the stock one?
