Cooler Master Hyper 212 EVO - Will it fit?
Tevrsre
6
I have a ASUS H87M-E LGA 1150 Intel H87 uATX motherboard. Will the Hyper 212 EVO overlap my ram slots or the PCIe slot? I don't want to buy a cooler that isn't going to fit my motherboard. My case is a full tower ATX so I shouldn't have problems there.
Link to motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131995
Edit: Since you asked,
Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108423
Ram:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
The fan will probably overhang RAM slot 1. If you have RAM with the unneeded 'cooling fins', there may be some clearance issues if you need to use slot 1.
Options:
2 x RAM sticks in 2 & 4.
Slide the fan up a little
Put the fan on the other side, in pull config
Options:
