I've recently installed the Hyper TX3 Evo by CoolerMaster (replacing my old Intel stock cooler) but since the first day, I've experienced some strange issues related to the fan.
The first day the fan was spinning at max rpm, till I managed to enable q-fan control on "standard" inside the BIOS, but after that I've noticed that sometimes when turning the pc on, the fan would not start at all (or start for a bit then stop immediately) giving the cpu fan error in POST.
Then after other testing, I've noticed that in some occasions the fan would totally shutdown 30 minutes or so after logging into windows (it happened inside the BIOS too), two times I was playing a game (when this happened, the "cpu fan" section inside Everest would totally disappear)
Yesterday I've made test the whole day, rebooting or shutting down and starting the pc again, the fan worked properly (no spinning issues or noises, it starts smootly) but I've noticed another strange behavior: sometimes, the idle/stress RPM was a bit off, for example in some occasions the RPM stays like this: Idle: 1000-1600RPM / stress: 1600-2100RPM and that's ok because the cpu stays cool and silent. But some other times i notice that the idle speeds change to 1700-2200RPM and under stress it stays always high like 2200-2600RPM (notice that I've tested with the same game, same internet browser and same idle situation with no other programs in BG) and to "fix" this I simply reboot and the fan would work properly for the entire session.
Can I assume that this is a mobo/bios problem or I have to request a refund? I'm struggling because I don't want the 15 days to expire before I can ask a refund (I bought the cooler on ePrice)
On a side note, I've also noticed that the cpu temp stays a little high when the fan is spinning at max speed (that doesnt make any sense to me), I dont know if is a fan reaction to high temp because it happens also when I set the q-fan on "disabled" and so the fan always spins at max rpm, the temps stays at 60c on idle, but when I set the fan to auto mode, at lower rpm, the cpu stays on 35-40c idle.
Hope someone can help me figure out somethin, my pc specs:
Cooler Master HAF932 (the case)
Cooler Master 700W Psu
Asus p6t (normal version with just one CPU_FAN slot)
i7 920
16 gb (4x4) corsair vengeance
i7 920
