shocked and intrigued? :lol:
Dissapointed - not in cooler master, the review.
No o-scope traces, no "in-between" load test info so you can't see where the CM failed to provide the juice. Was was the max per rail the unit did provide just prior to shutdown? Did it actually shut down w/ a breaker trip or blown fuse? Did they replace the unit and it happened a second time? No clue, all I saw was this
In a way, I am shocked and intrigued... I still have no idea if any of those units can provide a clean signal at min, max or inbetween :lol:
Oh well, read through the jonnyguru links in my previous post he provides a very detailed review and not just the results. SPCR also gives detailed load test data so you can chart the efficency / power factor nicely.
As far as Delta goes, I have seen quite a few pass through our datacenter as the OEM for server equipment, but not in the consumer space. A quick froogle search... hmm only one DPS-500HB A:
(link)
That's a tough fit... but typical of the Delta Server grade power supplies I have seen.
Any retailers on this side of the pond that you know of? If not I really will be shocked and intrigued...
