Cooler Master K380 and GTX 980Ti Amp Extreme
nickjay123
4
Hi, my motherboard is Gigabyte Z97-HD3, graphics card is Zotac GTX 980 Ti Amp! Extreme (12 inches long and 3 slots wide).
So, will I be able to fit the graphics card inside Cooler Master K380 cabinet?
The compatibility checker at Cooler Master's website says my graphics card is incompatible. But, the case description says that maximum supported length for card is 12.5 inches (without HDD).
Also, the max length for the card at 1st slot is 11 inches (I dont know what that means).
So, basically, my question is: Will I be able to fit the above mentioned graphics card into this cabinet? Thanks :)
The ZOTAC ZT-90505-10P GeForce GTX 980 Ti AMP...
The ZOTAC ZT-90505-10P GeForce GTX 980 Ti AMP! Graphics Card Length - 12.92 Inches
The Cooler Master K380 supports GPU with max length of only 12.50 Inches.
So clearly this card won't fit in this case.
Consider this quality case from Corsair that can support GPUs with length up to 16.53 Inches. Which means it can easily accommodate the ZOTAC ZT-90505-10P GeForce GTX 980 Ti AMP!:
Case: Corsair SPEC-02 ATX Mid Tower Case ($59.99 @ Amazon)
Total: $59.99
Generated by PCPartPicker 2015-08-01 13:19 EDT-0400
9EA996297FDE4C0DB3991D6701646DB0.ashx
Official Product Page - http://www.corsair.com/en-in/carbide-series-spec-02-red-led-mid-tower-gaming-case
Cheers!
Thanks, I went with Deepcool Kendomen
