fanchiuho :
Look, I'm totally following you for the first paragraph but not the second.
'Micro ATX is halfway between ATX and Mini ITX' is only consistently true in the context of motherboards. What the OP was referring to though could be the case market.
I just snipped two of the dimensions from official websites, one of which is the Mastercase Pro 3:
467 x 235 x 505mm = 55.42 L
464 x 232 x 523mm = 56.3 L
Guess which one is the Mastercase? The first one, which is in two dimensions larger than the second case, sans length.
What is the second case? A Define R4.
Like what?! This is my precise reaction during research, when I initially thought this as a worthy downsize from my *own* Define R4. So in the name of flexibility, they made a case less than 1L smaller than an already versatile mid-large ATX case, *and* limit it to mATX boards? Not an attractive proposition at all.
Prior to the R4 I was using an CM N200 so it's not like I am reluctant to use CM products. But I'm in the market for silent subcompact cases with updated features and it doesn't seem like there are any on the market now. And it just seems like Cooler Master over engineered the Pro 3 and totally missed the point of what FF a vanilla mATX case should fit itself in.
And this is the normal scenario.
Fractal design don't really make any SMALL cases:
Define S, http://www.fractal-design.com/home/product/cases/define-series/define-s, 23.3*46.5*53.3 = 57.7 liter (ATX)
Define Mini, http://www.fractal-design.com/home/product/cases/define-series/define-mini, 21.1*39.5*49 = 40.8 liter (Micro-ATX)
Nano S, http://www.fractal-design.com/home/product/cases/define-series/define-nano-s-window, 20.3*34.4*41.2 = 28.8 liter (miniITX)
Which is sad. Then again they may be more comfortable to place things inside.
If you try to find some of the smaller cases:
(miniITX)
SilverStone SG13, 22.2*18.1*28.5 = 11.5 liter.
Cooler Master Elite 120, 24*20.74*40.14 = 20 liter.
Xigmatek Nebula, 26*33*26 = 22.3 liter.
(Micro-ATX)
SilverStone FT03, 23.5*48.7*28.4 = 32.5 liter.
Corsair Air 240, 39.7*26*32 = 33 liter.
BitFenix Prodigy M, 25*40.4*35.9 = 36.3 liter.
The Corsair Graphite 380T is a miniITX case too but with a very shape and it's not really the 40+ liter you'd get from just multiplying the maximum sizes on each end.
(ATX)
Cooler Master HAF XB, 44.2*33*42.3 = 61.7 liter.
Corsair Air 540, 41.5*33.2*45.8 = 63.1 liter.
So yeah, I guess vs that the Micro-ATX cases actually sit inbetween.
Anyway I have a hard time considering a case 40+ cm on any side for small, in the most extreme case above the miniITX case has just 1/3 the volume of the Micro-ATX case. And yeah then there's cases for not full height slots and with risers and both can make the outcome smaller but Micro-ATX will still be huge in comparision in all cases I've found and for what? Room for another graphics cards and two more memory slots. The later I considered a feature with Z97 but as said don't really view as a necessity any longer and the former definitely not.
Crashman :
But you're not comparing the 23" EATX behemoths that this thing is a substitute for. And if you'd like to compare a slim Mini ITX case to something, you'd have to compare that to a slim Micro ATX case.
I currently use a Mini ITX case that's 2/3 the size of this monster in my office. It's designed for a big (huge) air cooler. I chose it to maintain minimum fan speed while stressing a super-fast CPU.
So if case dimensions are defined by cooler size, the only way to compare form factor scale is to compare the boards that define the form factor. Of course we could just start comparing slim Mini ITX cases, like my wife's, to slim Micro ATX cases, like we used to see in VCR-sized media center PCs, to slim ATX desktops, like the ones people used to prop up their monitors in the early 90s.
Without that kind of perspective, a person comparing my supersized mini ITX to the MasterCase Pro 3, and the MasterCase Pro 3 to some super-tall gaming case, will always end up facing off with a distractor comparing mini cubes to towers.
No-one was comparing different style cases, here's slim lines:
Lian-Li PC05S, http://www.lian-li.com/en/dt_portfolio/pc-o5s/, 38.4*46.5*14.8 = 26.4 liter (miniITX.)
Lian-Li PC06S, http://www.lian-li.com/en/dt_portfolio/pc-o6s/, 48.4*51.5*14.8 = 36.9 liter (Micro-ATX.)
Lian-Li PC07S, http://www.lian-li.com/en/dt_portfolio/pc-o7s/, 51.4*58.5*14.8 = 44.5 liter (ATX & E-ATX.)
If anything slim-line seem to benefit ATX more, likely because that mean you at-least TRY to make a small volume case in the first place.
I don't understand why someone want those large boxes, sure some people (enthusiasts more so if they like to collect their old smaller hard-drives and stick with them) will need it but take the popular Fractal Design R5 for instance:
2x 5.25" slots
8x 3.5" slots
2x 2.5" slots
And then we have people who just order their computer with a 500 GB SSD only. Yeah. Use that case!
Personally I think the desktop cases which sat under monitors was much more attractive than the towers which replaced them.
The tower is like a huge fucking wall blocking off half of the universe to either of your side
I don't want my computer to be a room separator wall.
