Question Cooler master MB530P ARGB splitter- I need help knowing how use it.
Dec 4, 2020
Hello I could really use some help with the case I am using to build this PC. My main problem is the 3 front fans they come installed with this ARGB splitter for RGB sync with MSI or Gigabyte but the problem being I'm not sure where to connect it to the motherboard.
Please include the make and model of your motherboard. We can help in identifying if your board has the header to plug the ARGB device splitter to. They are usually labelled as RGB or ARGB or DRGB or JRGB, depending on what your board maker is.
