cooler master thunder 450w vs GTX750 TI StormX Dual
angelito abalos
31
i will upgrade to Palit GeForce GTX750 TI StormX Dual 2gb 128bit DDR5
but my power supply is thunder 450w
is my power supply can drive the gtx750?
or what is higher than 750 can he drive?
thanks
There's no need to buy the 6in PCI Express Power Splitter Cable.
The ASUS GTX 960 STRIX OC 2 GB [STRIX-GTX960-DC2OC-2GD5] only requires one 75 Watt 6-pin PCI Express supplementary power connector.
The (6+2)-pin PCI Express supplementary power connector from the Cooler Master Thunder 450W (RS-450-ACAB-M3) can be used as either a 150-Watt 8-pin or a 75 Watt 6-pin PCI Express supplementary power connector. When used as a 75 Watt 6-pin PCI Express supplementary power connector the (+2)-pin portion of the connector is left unconnected.
Power Supply Requirements for a single GeForce GTX 960
NVIDIA specifies a minimum of a 400 Watt or greater system power supply. (Minimum system power requirement based on a PC configured with an Intel Core i7 3.2GHz 130 Watt TDP processor.)
the power supply must also have a maximum combined +12 Volt continuous current rating of 28 Amps or greater
• the power supply should also have at least one 75-Watt 6-pin PCI Express supplementary power connector. There are some non-reference design cards that require one 150-Watt 8-pin PCI Express supplementary power connector (e.g. EVGA GTX 960 SSC 2 GB [02G-P4-2966-KR], MSI GTX 960 Gaming OC 2 GB [GTX 960 GAMING 2G]).
Total Power Supply Wattage is NOT the crucial factor in power supply selection!!! Sufficient Total Combined Continuous Power/Current Available on the +12V Rail(s) is the most critical factor.
OEM: CWT (i.e. Channel Well Technology)
maximum combined +12 Volt continuous current rating: 30 Amps <===== Sufficient
one 150-Watt (6+2)-pin PCI Express supplementary power connector <===== Sufficient
Modular Output Cables: No
Official Intel Haswell Compliance: No
• No 80 PLUS Efficiency Certification
• 3 Year Limited Warranty
If your CPU has a TDP that is less than 130 Watts then it should work.
Post your full system specifications and you may get a more accurate answer.
Gigabyte GTX 960 G1 Gaming 2 GB [GV-N960G1 GAMING-2GD REV.1.0]
• two 75-Watt 6-pin PCI Express supplementary power connectors
• one 150-Watt (6+2)-pin PCI Express supplementary power connector
You would need to get one of these PCI Express Power Splitter Cable:
http://www.startech.com/Cables/Computer-Power/Internal/6inch-PCI-Express-Power-Splitter-Cable~PCIEXSPLIT6
Or get a GeForce GTX 960 that only requires one PCI Express supplementary power connector.
i was having a another problem. my mobo is only an 2.0 pcie. if ever i buy an ASUS Graphics Cards STRIX-GTX960-DC2OC-2GD5 (3.0 pcie)
can my mobo run the 960 on full specs?
I want the asus gtx 960 sir ^__^
