Question coolermaster fans flickering with msi mystic light sync
bashenderiks
43
Hello,
i just builded my new oc, with the coolermaster mastercase h500m, as you may know it has 2 argb fans pre installed. so i connected the 2 fans through the cotroller that comes with the case, and i can change the fans in the msi dragon center with mystic light. but when i put on a colour the fans start flickering, this is only if i change the colour with the msi mystic light program, because when i use the reset button the fans arent flickering, anyone know why?
Kind regards
Make sure you're on the latest BIOS update for your motherboard. You might want to see if you've connected the aRGB connector in the right way, taking note of the arrow on the connector. This is a troubleshooting thread, which is why you're going to have to include a bit more info, such as your system's specs and how they're(the fans) connected to your motherboard.
List specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
