Hi everyone,
Before i start drilling holes and wasting my time, i thought i'd ask the experts for some advice.
We've just given our home office a makeover and have moved the PC tower, which previously lived on the floor by my feet, into a cupboard. The cupboard itself is about 50cm deep and a metre or so wide, but only has a door at one end (the front-most 50cm or so). Logistically, this means the PC is lying on its side (on the side without any air holes etc.) with the rear of the unit facing the side of the cupboard. A picture will probably help (taken mid-decorating!);
With the door closed this cupboard is fully enclosed, save for a small hole (about 10x2cm) through which the cables are routed. They then route behind the cupboards on the left and up to the desk to the left of those drawers. With the door closed, the PC idles at around 40C, whilst getting up to mid-70s (gpu) fairly quickly when gaming [note i havent done any proper racing with this, but did have the computer running a replay from a previous race to replicate fps/computer load etc.)].
What is my best solution here, to keep temperatures in check. I think options include;
1) open the cupboard door whilst gaming to allow cool air to get to the front of the unit (i could obviously try this fairly easily)
2) replace the panel in the door with some form of mesh/latticing (something like this - https://i.pinimg.com/736x/d5/74/10/...34be0--decorative-panels-decorative-metal.jpg) which would allow air in at the front
3) drill a hole(s) at the rear of the unit to allow air to escape. Note that behind the rear of the unit is a 3inch gap to the wall, but air could perhaps flow left behind the cupboards and edge of the desk, emerging somewhere near my feet.
4) do something similar to the above, with the addition of a fan to push warm air out of the unit
5) drill some air holes through the wall into the garage, either for the air to move to or using some form of extractor fan
I worry that 1 and 2 will only serve to get cool air to the front of the unit, but provide nowhere for the warm air to go (unless i can get it to recirculate with a fan, perhaps). With 3 and 4, will either of those be enough to allow the warm air to escape quickly enough, or does the vent need to be much more significant (hence 5). And if 3 and 4 would be sufficient for the warm air, would it need to be in concert with 1 and 2 (so cold air can get in and warm air escape)?
Alternatively, would some form of water cooling system be a better (though more expensive) solution - or does that also need somewhere for the warm water to dissipate too so is just a case of moving the problem around? I presume i could, in theory, pipe the warm water to a radiator installed somewhere cool (i.e. the garage, through the wall)? But that doesnt sound cheap...?
For context, PC itself is fairly old, i7 870 and a GTX 560 (though i do plan to upgrade in the not too distant future.
