Hi. I'd really appreciate some advice as my PC is away being fixed, under warranty, and I need to make some fast decisions about its repair!
The CPU is an i7-4790K. I don't overclock it - it's at the standard 4.0 GHz. I have noticed that the core temperatures, as indicated by the CoreTemp utility, although fine at 'idle' - often not exceeding 30-35 degs C at an ambient of c.20 degs, with all CPUs at 100% (7-zip tends to do this, and one or two games, especially X-Plane 11, as it loads up), I was getting core temperatures of up to 98 degs.
The folks that put the PC together (well thought-of, mostly, on the internet) tell me that under severe tests they got to 100 degs, so they re-pasted and re-seated the cooler (a Noctua NH-L9i) and that under stress the temps are now about 90 degs max, which they think the system will be 'happy with'.
Can't say I am all that happy though! That still sounds way too hot - and not much of a change from when I sent it back. They say that they could put in a Corsair H60 water cooler instead, which "would probably bring temperatures down only by about 10 degs on average" (not sure I want a water cooler, ideally, but...).
BTW, there are only SSDs in the PC, no heat-generating HDDs. (And a GTX970 4GB GPU).
The problem is compounded by the fact that this is a small form PC, in a Coolermaster Elite 130 case. (Asus H97I Plus M/B). Not much I can do about that without a complete rebuild.
I can't make my mind up what to do now. Anyone have comments or other suggestions as to cooling in this system?
Thanks!
Martin
Thanks!
Martin
