Hi, I just finished putting together a PC with an i7 8700K with an AIO Water cooler and the cpu temps are a constant 24-25C on almost all cores.....is that very good?
Also, can I lower the fan speed to decrease noise issue just enough so CPU is still below 35C Idle temp?
Fans are quite loud even though they operate at a normal idle usage speed and creat great temps too...
PC Case: NZXT H440
Water Cooler AIO: Corsair H115i
Fans: Case Fans (They are loud)
(AIO Fans are kind of loud too)
PC Case: NZXT H440
