Cooling an FX-6350
As high as your CPU chip and motherboard allow. A decent liquid cooler mostly stops heat from being a concern before the chip starts to become unstable.
gamer2321
292
What is your budget ? a water cooler is recommended on my behalf as the AMD FX's tend to get a little hot however if your on a tight budget a good air cooler should do. Give me your budget and I'll recommend non other than the best bang for your buck.
EdkinsGamingYT
24
$200
It doesn't seem wise to spend more on a cooler than you spent on the CPU.
A Corsair H60 should work, and it's petty cheap.
EdkinsGamingYT
24
What clock speed do you think I'd be able to reach?
