In the past year I've owned this CPU I've replaced it's motherboard and power supply to support it's TDP (I was not the one to choose any of the parts in the first place and I regret not enforcing that but that's behind me). The cooler I have attached to the system now is an H80i with both push and pull fans on it that came with it. These fans are set to 100% at all times. The CPU overheats to 65 degrees and the speed drops to 1.75GHz when this happens at stock clocks at 8 cores, at 2.9GHz with six, and all the way down to 2.5GHz with 4 cores. This can happen when the system is turned on and idles for 20 minutes as well (closing anything that would have taken CPU time minus AV will do the same). At the moment I don't have a set budget but what I would like to know to know is what would cool this CPU?
I live in southern Canada so my coldest season is ending, and it gets rather humid here in the summer. Dust shouldn't be a problem. The room my computer is in will have an air conditioner in it around May-June through to early September. Temperatures outside in the summer generally won't go over 37 degrees Celsius, so without it I have no chance of running this PC.
My case is an NZXT H1 Classic, and unfortunately the in-case fan control system has it's power-supply connector broken so until I re-solder it the front HDD fans are removed. I have one 120mm fan in the bottom of the case, and my H80i is mounted in the top 120mm slot. My 140mm slot is unused, although I'm still not sure if it can support a 140mm rad I'm willing to try it. Temperatures in the case don't pea 40 degrees and tend to hover just over 30. Nothing but the CPU ever reports being hot in the case. The Graphics card has adequate cooling, as do my HDDs.
If I can find a fan bay for my 3 unused Optical bays I will put a 120mm fan in it (or just wedge a 140mm fan in it with foam and zip ties, I've seen it done before) if it will help me direct air to the radiator in the 120mm slot at the back of the case.
(Edit) My motherboard is an ASUS Crosshair V Formula-Z.
