[SOLVED] Cooling antex nx200 case
Jun 28, 2020
Antex nx 200. This case supports 1 rear , 2 top and 2 front fans . But it does not have proper vents for the front fans. So suggest me the best cooling that I can do for this case . I thought of using rear as intake and top as exhaust and not using front as it doesn't have proper vents , is it gud?
No that configuration will never work properly.
While the nx200 has a solid front it has fairly big intake vents top and bottom, it'll be fine using front intakes in my opinion.
Leave the preinstalled fan in the rear as exhaust and add 2 x 120mm fans as intakes to the front.
Leave the top exhaust vent clear.
