Hello guys I need help. I recently transfered my pc to a new case and replace the cooling fans. After everything is installed the same as before then the psu suddenly died. I replace it with another psu then my pc turned on but the fans died. It made a sparking sound and had a burnt smell. I bought a new brand of fans and installed it. Then the result was the same. All the fans died. The rgb light is not working. It also made a sound and had burned smell. The only thing i replaced from the original setup before my first psu died was the psu connectors. I dont know what to do. I dont want to spend money for fans and kill it after installing. Thanks
cpu - i7 6th gen
Mobo - asus z170 pro gaming aura
Ram - corsair vengence 16gb
Psu - corsair rm1000(died) / thermaltake 750w
Gpu - asus gtx1080 ti
Fans - dark flash dr12(died) / pc cooler corona rgb (died)
cpu - i7 6th gen
