G'day guys,
Long time reader, first time poster.
This is more of a 2 part question, that involves overclocking as-well as cooling.
But I'll see how I go here first, as my concerns are more cooling orientated.
I recently built myself a new PC (thank's tax return!)
In this build I purchased myself an i9 9900k and a Ryjin 240mm AIO cooler.
At base clock speeds, I'm getting good temps, sitting around 45c under load.
Now, I thought I'd push to try and get 5.0Ghz instead of the base 3.6Ghz.
I was able to achieve 5Ghz with 1.275v
however I did experience the one off bluescreen using Heavy load, but not from benchmarks, i.e Cinebench.
I tried increasing the voltage to achieve 100% stability (if that even was the issue), so much as 1.0volts, I was peaking to temps of 96c.
My current configuration is:
Cougar Gemini T RGB Tempered Glass-Wing Mid-Tower E-ATX Case
Running 3x Cougar RGB fans on the top as exhaust fans.
2x fans on the side panel as Exhaust fans
1x fan on the rear as exhaust
My AIO is on the front panel of the case, with the 2 fans covering the 240mm radiator. (also to note, this cooler also has a small, high rpm fan on-top of the CPU as-well).
While my GPU has 3x fans, side mounted, drawing in air from the sides of the case.
My fan profile (all fans excluding GPU) is set to:
Fan speed (%) Temp (C)
30 40
50 60
100 70
Any suggestions on whether my current configuration and settings is sufficient cooling for the i9, or whether it may be an overclocking error I'm making?
I've previously read, that the OEM thermal paste is sub-par, so I'm going to remove it and apply Thermal Grizzly Conductonaut Thermal Compound.
thanks for reading, and thanks in advance!
30 40
50 60
100 70
