[SOLVED] Cooling for Ryzen R7 1700x
Zeplyn
23
Hey,im doing a pc build and am wondering if I only need a NZXT Kraken M22 120mm RGB All In One CPU Liquid Coole or if I need the 240mm one for cooling, Any help would be awesome as I do have a budget also,would a coolermaster hyper 212 be enough or what do you recommend
I've been using the AMD Ryzen 7 1700X for a year using an AIO liquid cooler. My cooler is 360mm and is overkill. A 240mm should be fine. Basic rule of thumb is one fan per component cooled.
