Hey all, looking for some input:
Just upgraded my system from OC'ed AMD 8350 to Intel 5820K (4.3 OC @ 1.26 Volts, ASUS x99 Deluxe MB). I am using the Corsair H100 in a push configuration that I have had since late 2012, early 2013. I am using a CM Storm Trooper for the case. My temps are OK when I game (never over 60 degrees C as far as I can tell). The cooler may be working fine I am thinking of changing the cooler just because I want to upgrade. Here is where I would like input:
I am thinking of moving to a AIO 280mm radiator such as these: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100008008&IsNodeId=1&Description=280mm&name=Water%20%2f%20Liquid%20Cooling&Order=BESTMATCH&isdeptsrh=1
But I am also considering moving to a big air cooler (none in particular yet). My biggest concern with big air is that I do move my computer between levels of my home (2 stories) on a a frequent basis and I have heard that the massive coolers could damage a system when moved. But I am always worried that one day my AIO will leak. Any helpful thoughts appreciated on the situation
