I purchased an Arctic Freeze 7 Pro Heatsink and fan about 4-5 yrs ago for my Intel Q9300 through newegg. The fan is on its way out and I am looking to just replace the fan. The temps are fine but I cannot find any replacement fans that clip on to the heat sink...just the ones for the cases.
http://
Is there anyway to just get the fan or must I purchase an entire HS/Fan combo? I would have thought it would be as simple as putting in 92mm fan, and maybe it is. Do the case fans work as CPU coolers via heat sinks?
Thanks in advance
http://
Thanks in advance
