cooling suggestions for i-7 5960x OC to ~4.4 GHz
harsh2art
13
I am a novice at OC or cooling systems.
I am building a workstation, 24/7 use for 3D CPU /GPU rendering. These are main components I have in mind, I am open to suggestions. Will be using all threads running at heavy loads.
i7 - 5960x
64 GB RAM
Quadro M4000
X-99 motherboard (open to suggestions suited for OC)
I was reading about temperatures crossing 80C when overclocking 5960x. Which cooling component should I buy?
Any suggestions on how can I get maximum CPU performance would be really helpful.
Thankyou
If the chip gets too hot, it just goes into thermal shutdown and turns off the system. What are you doing that you're running it 24/7 overclocked at 4.4? If you're doing that, wouldn't you want to stick to the side of stability and run it at stock speeds for stability?
I have no experience in overclocking so I am scared of overheating my 5960x CPU.
This is where I would suggest you do a LOT of research in how to overclock...especially if you're using a $1000 CPU as your first time overclock. This isn't something where you want to use a Windows application for overclocking...you want to get into the BIOS and manually adjust your settings appropriately - and avoid the +20% overclock button.
This is where you can potentially...
