cooling system advice
Mohammed Kamal
34
i wanna to buy i5 7600 and i wanna to buy hybrid cooling system and i was looking for something like kraken x52 or Corsair Hydro Series (h105,h110i,h115i) i rly need some advice pls help me 🙁
The biggest issue is the fans. They are the only part that really makes any noise whatsoever unless you get a crappy pump. I own both a corsair H55 and a kraken x61 and both are dead silent except when submitted to stress testing, and then both are relatively quiet. However, I did replace the fan on the h55 with a Noctua nf-f12 I already had, because Corsair's SP120L are absolutely miserable fans. Both use Asetek pumps (the round ones) which are superior, Swiftec uses their own hybrid Asetek. The h100i series uses CoolIt pumps (square) which are hit or miss and the Eisberg are awful. I get 0 pump noise, even under a 4.9GHz stress test on my i7. Most complaints about pump noise come from the Corsair lineup, but what else is new when they...
thx for ur help mate <3
